- Rainy side of Washington
You can usually get TCUs cheap at salvage yards, I spent 10 bucks on the one I started tearing into.
What did you find when you got in there?You can usually get TCUs cheap at salvage yards, I spent 10 bucks on the one I started tearing into.
Yes, that would work if I lived in an area that had well-stocked yards. Here we have only two, one with about 20 cars two of which are Jeeps but neither with the AW4, and the other has no Jeeps at all. I was hoping to avoid a 250-mile round-trip drive to a major metro area ...
I've figured out most of how the hardware works (at least, the solenoid drivers and the CCD bus interface) but I haven't successfully pulled the firmware off the microcontroller as I don't have the correct adapter/routing board to make it fit into my EPROM reader/burner. It's a mask ROM microcontroller anyways so there's no real point, you can't reprogram the firmware anyways. I'm just curious by nature.What did you find when you got in there?
Were you trying to reverse-engineer it?
Were you able to draw a schematic, or at least a partial one?
I want to know where to get the connector for the TCM for a 2001 XJ.
SPOBI, no it isn't. 00 and 01 use the same part number as 99 and 98, 5604 1386AA/AB.The 2000 and 2001 transmission control is incorporated into the ECM, no separate TCU.
Try Ebay, maybe get the dash harness, or check online junk yards!!!
The plug and socket are made by TE Connectivity -- formerly known as Tyco and AMP.I too am looking for the plug with wires to make an in car diagnosis station. I have a couple spare tcu's but my local yards lack any auto xj's. My AW issues are not consistent so i need to be able to test as they arise. Any one else ever made anything like this?
Read most of this great post..
Maybe a dumb question but I don't know the answer..
Are any of the 3 solenoids in an 98 AW4 used in reverse?
Shift solenoid 1 is energized during reverse. And the tcu will not engage the torque solenoid (#3) while in first. I made a tcu diadnostic tool if anyone is interested I posted it on cf but am willing to post it here.
Here it is as promised I pasted it from the site I originally posted at, any questions please ask.Stop teasing us, LOL, post it up, share!!!!
well I gathered all the bits to finally make this so here it is. I made it for 96 and earlier aisin warner Transmissions. I took a old TCU and un-soldered the female plug and mated it with the male plug from a junker. I attached pigtails for molex plugs so the unit can be unattached leaving the harness in place. There is a provision where the ignition hot input is switched through my diagnostic tool as I suspect I am losing that signal intermittently while driving.
Each function of TCU is represented by a colored LED and a voltmeter connected via a 11 position rotary switch. There are 10 functions I am reading and I left an extra position for an addition that may come up. The Functions are as follows.
1. torque converter lockup
2. shift solenoid #1
3. shift solenoid #2
4. Brake switch
5. shift lever position 1-2
6. shift lever position 3
7. constant hot
8. ignition on
9. Throttle position sensor (TPS)
10. Trans output speed sensor
There is also a ground and a TPS ground. The TPS ground must be used for the TPS signal LED to work I cannot read the voltage on this one function because the voltmeter uses the common ground. I will have to use a separate voltmeter If I want to read the voltage but the steady glowing increase of the LED is sufficient for now as an analog needle would be preferred for that function anyway.
The constant voltage to the Tool is switched so I can leave it in the jeep without a draw on the battery. The second toggle switch is so I can interrupt the ignition voltage and switch it to the constant voltage. This was done because when I have my intermittent problems the problem can be remedied by cycling the ignition and now I can do this without killing the engine.
To sum it up I can see when the Torque converter is locked, what gear I am in, The output sensor signal, and the other stuff listed above. I also will know if I am not in a gear the TCU is telling it to be. One more plus is where I dont have a stock clock I will permanently install LED's for the gear and torque converter with a manual locking switch that will automatically unlock in first gear so as to avoid stalling the options are great for manual control. Can you say paddle shifting? Manual or auto mode would be killer.
The total cost were around $50. and I could have done it under $20 if I didn't have to source the TCU plug from a junkyard via mail. I need to add labels so I wont forget what is what. Here are the pics.
