- MilkyWay Galaxy
1989 Cherokee ltd. 4L, AW4, NP242, 3.55, 'RENIX'
how difficult is it to replace the torque converter lockup (clutch?) and / or solenoid ??
How can you test to see which is the problem ?
actually I assume that if is slips at all - for years - the clutch or 'lock-up' surface needs replaced.?.
How viable is a later model junkyard one?
how much modification for JY parts?
AnyOne?
The lock up clutch is inside the TC, it is not servicable.
Solenoid #3 , botton side of the valve body, activates the TC lock up in high gears at crusie with the brake off. So bad wiring, bad brake switch, bad TPS (confusing the TCU), bad #3 transmission solenoid, or bad ground on any of those parts can keep from the solenoid from turning on and locking the TC up in the first place.
