- Southern Maryland
a vacuum gauge is only $20 will tell you right away if there is a leak
Does this get hooked up to any vacuum line on the system? What PSI should it read?
Edit: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93547
I'm searching right now for some instructions. So I can splice the vacuume gauge anywhere in the vacuum system and it should be 15-17" Hg?
Hum.
As the engine rev's, it creates more vacuum, right? So as the engine is rev'ing up and down, the vacuum should go up and down?
Thanks for the guidance. Now I want to get off work early and hook it all up and see what it's doing. I sure hope it's not a HG problem.
Not sure how I missed that thread, but it's basically amazing.
really hard to correlate that stuff without a tach
blind shot in the dark is timing chain
