Engine taking longer to catch
wolf2600
Austin, TX
99 XJ Sport, 4.0L, 125k miles.
Just noticing that it's starting to take longer for the engine to catch when first starting it in the morning. 3-4 seconds of cranking rather than the 1-2 seconds it previously took.
Not getting any engine codes, just wondering what to check.... plugs? fuel? sensors?
What is the condition of your "tuneup" items--plugs, wires, cap, rotor?
If all of those are good, how is your battery's load capacity? Have it tested with a carbon pile load tester, 1/2 CCA rating for 15 seconds, not dropping below 10 volts.
Not sure about the 'tuneup' stuff. Just bought it a couple months ago, and have been fixing/replacing the more obvious things (tires, shocks, sagging door hinge).
The cap and wires look clean/newish, but without actually having a new set of wires in hand, I'm hesitant to pull one to check plug condition (don't want the wire to separate when I go to pull it off the plug).
I'd worry less about ruining a wire, especally if removed properly. Any wire in any kind of decent shape will not "separate" when pulled off properly. Reach all the way in and firmly grasp the boot, no pliers, no just yanking on the wire.
I've had the current set of wires for a couple years on both my XJ and MJ and I've had them on/off at least a half dozen times with no problems. Can't really tell much by just looking!!
Your other option is to just turn the key to "ON". Count to 5, then turn the key to start. See what happens.
I agree with Tim about the check valve. When my 98 did what you're descibing, it was the fuel check valve in the top of the fuel pump/sender assembly in the tank. If the check valve is bad the fuel pump has to refill and pressurize the fuel rail before the engine fires, thus the longer cranking times while it reaches pressure. You might try cycling the key to "on" several times before you turn it to the start position, leaving the key in the on position 3-5 seconds before cranking. If it then fires like it used to, it's more than likely the check valve.
I think that has something to do with it. When I turn the key to on, and wait a second or two before cranking, the engine will start up quickly. But if I don't wait that time before cranking, it takes longer to start.
Just need to let the pump pressurize the fuel system before trying to start.
Mine does the same thing, 97 grand Cherokee.
I turn the key till the door bell stops, then it starts right up no problem.
dobe
The check valves (there are two of them; one on the fuel pressure regulator and another on the fuel pump) are part of the fuel pump assembly on 95.5-2001 vintage 4.0 XJs. When a check valve starts to fail, it can reduce fuel pressure to a point where an extended cranking time is needed to start the engine. It is a very common failure. I experienced it on my 99 at around 75K.
A good (and simple) first step in helping you troubleshoot this problem is called “the poor mans prime”
1. Turn key to ON position (do not crank the engine!)
2. The fuel pump will energize and run for about 2 seconds. Be sure to wait until it stops running.
3. Turn key to OFF position
4. Repeat above steps 1-3 two more times
5. NOW crank the engine over
If the engine starts quickly and cleanly after performing this procedure, you may have a check valve issue. If it starts and runs poorly for a few seconds, it could also be a leaky fuel injector resulting in the fuel pressure leaking down and the subsequent stumble upon startup is the engine clearing the excess fuel that has leaked into the cylinder because of the faulty injector.
Also be aware that a bad battery can give you starting symptoms as well. Have your battery load tested (any parts store will do this for free) if you have any doubt; your XJ does NOT like low available battery voltage. Be sure battery connections and posts are CLEAN.
Some troubleshooting tips for extended crank times. You will need a fuel pressure gauge. Many parts stores will rent you this tool inexpensively.
*Hook up fuel pressure gauge on the schrader valve on the fuel rail under the hood
*Start engine and bring to normal operating temperature.
*Observe fuel pressure gauge. Normal operating pressure should be 49.2 psi (plus or minus 5 psi)
*Shut engine off.
*Observe pressure on gauge. Pressure should not fall below 30 psi for five minutes.
If pressure falls below 30 psi, it must be determined if a fuel injector, a check valve within the
fuel pump assembly, or a fuel tube/line is leaking. An adaptor tool/hose included with the fuel pressure gauge can help you with this. Consult the manual that comes with the fuel pressure gauge and the Factory Service Manual for your year XJ for more information on this exact procedure, but here is basically how it works:
*Turn the engine off and immediately clamp the fuel line at the adaptor hose. Watch the pressure gauge and see how long it takes to lose pressure.
*If the pressure remains at 49 psi for an extended period of time then the problem is in the tank – most likely a check valve. If the pressure falls below 49 psi fairly rapidly then the problem is probably a leaky fuel injector.
**Note. Where check valve is suspect, a quick loss of fuel pressure is often the fuel pressure regulator check valve and a slow loss of pressure is often the fuel pump check valve. But keep in mind that either or both check valves can be to blame.
You can limp a check valve problem along indefinitely if you like, as it doesn't mean the fuel pump itself is going to fail. Perform the “poor mans prime” before cranking to speed up your starts. However, if you have a check valve issue and want to resolve it, it is recommended that you replace the entire fuel pump assembly for two reasons. First, you have to drop the gas tank to access the assembly. Secondly, with two check valves, replacing just the fuel pressure regulator where one of the check valve resides may or may not resolve your problem; remember there are two check valves; the other one is on the fuel pump.
The fuel pump assembly consists of fuel pump, fuel pressure regulator, fuel gauge sending unit, fuel gauge float, pickup filter and pigtail wiring harness. If you do replace the fuel pump assembly, purchase a high quality unit; you do get what you pay for here. Some cheap aftermarket assemblies have been known to fail prematurely. I personally prefer Bosch fuel pumps as they manufacture the best fuel pump assemblies for the XJ. Carter is my second choice. Airtex is my least favorite choice and I will not recommend or install them.
When my '93 would do that I always threw some injector cleaner into the tank and after a couple of days, the engine would be back to normal. When injectors get clogged they don't vaporize the fuel as well and can make for a hard start. Easy thing to try.
Very new guy here, just joined today, saw a link from Cherokee forum. This is the type of thread I've been looking for. I just bought a 2000 Cherokee Sport 2 door. It takes WAY too long to start. The poor mans prime doesnt help. The only time it starts like it should is the very first start of the day at 540am. Otherwise the rest of the day, it takes a long time. I am going to find some injector cleaner, but this has been bugging me. I've only had it for 3 weeks. Runs great after its finally started. Any ideas?
Also, replaced coil rail and all the plugs because it said cyl 5 misfire, and the codes came back. Gonna check them again tomorrow to see what codes came up again. Thanks guys!
The coolant temp sensor may be out of spec and that could cause the PCM issues with hot starts.
