MoparManiac
- Amherst, NH
How bout I don't and you just tell me what you're running cam and compression wise and maybe a horsepower and torque number, if you know any of that
My first 4.0 didn't make it to 200k without additives. That's not my point, who knows if running better oil and maybe additive could've prevented it. I eventually cracked a piston and when I tore the engine apart the cam was in pretty bad shape. My point is that you having good luck with a few 4.0's doesn't make it law that ZDP is useless in them. There's a difference between causation and correlation.
How many times do I have to say that I don't think ZDP is necessary??? I also never said anything about it being "financially beneficial", try reading, it helps. What I said was that for as cheap as ZDP additives are, it's a good idea to use them.
Also, the additive I use is just under half of $5 so according to your math it would cause me about $150 every 200k miles. Is that worth it to me to decrease my chances of an engine failure? Hell yes it is.
I think it's hilarious that you're arguing against scientific fact. ZDP decreases wear on metal parts. The 4.0 is made of metal parts. Less wear = tighter tolerances = less chance of parts failure.
But I guess somehow the 4.0 is an exception to the laws of physics![]()
And here we go with the insults
You have 0 proof with your claim since you didn't provide any information on what happened to your engine.
I, along with SEVERAL others, have actual evidence that there is no noticeable decrease in performance/durability/reliability when not running ZDDP additives in a 4.0. Did I say it was law? Nope, but you don't have any EVIDENCE to back up your claim that it's beneficial other than people claiming it is.
You ARE making a financial case out of this by introducing the cost of the additive. I don't want to spend that kind of money every oil change (I did one every 1.5 months due to how much I drive) because the benefit couldn't be proven to me. Maybe if I had a high dollar, high performance engine, but the 4.0 is neither of those two.
You can't prove it decreases the chance of engine failure. According to who?
The 4.0 isn't exempt from physics, it's exempt from your horrible attempt at trying to rationalize the fact that ZDDP additives just give you a "warm and fuzzy feeling inside".
