- Camden, SC
Are there any good laymen termed books and or sites I can go to to learn about this kind of stuff? I know an engine is refered to as a air pump (the more air in and out the more power) but what about torque? Does it raise proportionatly with HP? Like I told Mike and Andy at the crawl I'm on a steep learning curve here. I've never built an engine or done a lot of engone work. But, I want to learn and gain as much knowledge about it as posiable.
the block has been decked to bring the pistons to +.020 for a quench clearance of .045 when using a Felpro head gasket.
rods are shotpeened and have good bolts...crank turned and nitrided..rotating assembly balanced...main bearing and cylinder head studs.
