Engine coils..........
78/xj88
Orlando FL.
Just wanted to see what anyone has to say........
My XJ was not starting so i pulled a plug and tested the COIL no spark at all. So i went down to my local parts depot and got a new one, put it on and turned key.....nothing......then i turned the key back and forth 3 or 4 time ( i read in a post that this does something to computer mabey reset ? ) and whamo she starts up just fine .
??????????? Any input will be nice. I did not want to post in OEM it runs now so we will see time will tell. Thanx 4 the input in advance !!!
Often enough when there's no spark it's a problem with the crankshaft position sensor. Seems like in your case it wasn't. Problem solved would be good enough for me!
:cheers:
