Engine bogging down on startup
Overdriven
NAXJA Member #1020
Dayton, Ohio
Did the HO swap into a '88 XJ. I had the engine running in the '90 XJ it came out of. I'm fairly confident I've got everything set up right but it won't fire. I do notice that it bogs pretty hard every few cranks.
I used the 90 block, head, intake
I used the 88 computer, wiring harness, flywheel, flexplate, distributor and sensors.
Where should I start looking.
Thanks.
Got it all fixed up. Buddy dropped the distributor in a tooth or two off. Now it runs great.
Swapping in a HO motor is a great mod. I couldn't have done it without all the info I gained from being a NAXJA member. Thanks everyone for all the info you share.
