BPB
- Battle Ground, Washington
I wasn't sure where to post my new discovery. If this doesn't qualify as OEM tech please remove it.
When I went to rebuild my rusty 40 year old highlift I needed to remove rust. I debated on having all the parts hot tanked, but then I came across this article.
http://m.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
Despite being told it would never worked, I decided to give it a shot. Washing soda was $3 at walmart. Other then that I had everything else in my garage.
I used some 7x1/2" bolts I had left over from an old project joined together as electrodes. Them used my battery charger for power. This is what I ended up with.
Because of hydrogen gas being a byproduct I left the garage door open with my exhaust fans on. After hooking up the leads I fired it up. I decided more is more so I ran my charger at 12v 50amps. The results are impressive. After a few hours in the bucket, and a quick scrub with my wife's kitchen scrubber this was my result.
I was very impressed with how well it got the intricate parts clean where I would have spent an hour with a dremmel. The one spring that wasn't included in the highlift repair kit came clean with just wiping it off with a shop towel after soaking 30 minutes or so.
