Could you give some information about your vehicle - year, miles, etc. If you add that to your
profile would help a lot.
I have a 88 XJ and had a similar failure a year ago. The XJ would run but no radio. I turned off the XJ and restarted it and those things worked. I concluded it was a bad ignition switch.
The ignition switch is located on the column, I am not talking about the lock cylinder. Here a picture of the two styles used on my 88 XJ.
* tilt steering
http://www.smpcorp.com/mycgi/ibg.asp?parts=US105
* non-tilt steering
http://www.smpcorp.com/mycgi/ibg.asp?parts=US95
Notice how the switches look like mirror images of each other, make sure you get the right one. Expect to pay $10 to $15 for a new ignition switch. Notice on the listing Jeep used this "GM" switch through 1996 so good chance you have one of these switches.
A buddy of mine who a mechanic on the side told me to expect that switch to fail anytime after 120,000 miles. He recommended changing it out at 125,000 as preventive maintenance.
Also you can change the dimmer switch at the same time if you are worried about it. You have to remove the dimmer switch to gain access to bolts holding the ignition switch on. I did not change my dimmer. On my 88 XJ I needed a set of metric ignition wrenches, got the set at sears for $10 or $12.
While you have the lower trim off the dash it would be a good time to change the head light switch. I had mine fail 10 days after I did the ignition switch. That would not of been bad but I was 200 miles from home, it was dusk and had another 250 miles to go that night to get to my hotel in St Louis. Expect to pay $12 to $15 for the headlight switch.
Hope that helps.
