I didn't buy it, but someone did because it is no longer available -- all available units were sold a long time ago.
It was reported to produce significant power gains in the higher RPM range, at the expense of requiring high test fuel and increasing overheating problems. Also, the factory specifically recommended against towing with that computer, apparently because it reduced low-end torque.
You didn't post what year XJ you have, but that factory hi-po ECU was only offered for the Renix (87-90) model 4.0L
