GroversXJ
- Peoples Republik of Kalifornia
I know about using the pass-side E-brake cable from a YJ but wouldn't it be easier and cheaper to just fab up some new mounts out of some angle iron and weld them to the bottom of the cherokee maybe 4-6" further back than the current mount that holds the sleeve the cable slides thru. Then just adjust the long threaded rod the cable connects to back that same distance and viola no e-brake cable problems and you don't have to pull off the drums and remove the stock cables and string the YJ cables thru the backing plate.
Am I missing something there because I've looked at it a couple of times and it looks like it will work fine I'm just trying to get better with welding before I start any project now that I have a welder.
TIA
TIA
