Safari Ary
- Virginia Beach, VA
Ok, I get DW right at 60 mph as soon as I hit the sligthest bump in the road. If I hit a bump with the driver's side tire it gets really ugly, but if it's the passenger side tire i can usually steer out of it. Now sometimes the DW is more pronounced than others, and it seems to be dependent on the weather
Anyway, the part that really has me puzzled is that if there's a passenger in the Jeep, she runs smooth as can be, not even the slightest hint of a wobble.
I've changed all the TRE's excecpt the one at the end of the draglink(putting in a whole new axle here shortly, so I didn't wanna drop the coin for a new draglink). I'm 95% sure the Balljoints are good. I've checked all my Control Arms and trackbar for loose or worn out ends, and they were all in good shape(all have been replaced within the past 6 months anyway). My driver's side wheel hub has a LITTLE bit of play in it, but I've had bad hubs before, and this isn't what that feels like to me. The passenger's side hub is solid. I've checked the toe and it's good(1/4" toe-in). I've had my tires balanced and re-balanced and rotated and no difference was noted.
Is my Jeep just possessed? The new axle will go in here in about 2 weeks, but if there's something obvious I'm missing I'd like to fix it so I don't have to deal with DW for two weeks. I guess I could just put something that weighed 150lbs in the passenger seat
Thanks
Ary
Thanks
Ary
