Durango Power Steering Pump
Get the gearbox from carparts.com. You can snag a used one for about 60 bucks. Did it on my 89 and it worked fine. Also upgraded to the Crok plates and ended up replacing the pump as it started sucking air through the seals after I put the sythentic oil in it. JUst used a stock pump. If you want to get more out of the stock pump, pull the o-ring in the input port(I think) of the pump. There more info on doing this if you search.
