hubs97xj
- Fort Wayne, IN
From your pic of your drum. Max Dia 230mm. To convert from mm to inches, divide mm by 25.4. 230/25.4 = 9"
You could also measure the drum.
Update:
I HATE drum brakes... but managed to stumble thru getting a new wheel cylinder, shoes, springs and drum on that passenger rear which was shot and soaking wet w/brake fluid. I could see it dripping out of the old wheel cylinder once I finally got everything off.
I took pics and even printed them off, but I had to pull the drivers side drum off and see how it all went back together... back and forth many times. Adjusting the shoes was not as easy as one would think... hard to really tell much difference when turning that "adjustment 'screw' "
Also swapped out some new front brake rotors and pads. Trying out the Black Magic brake combo up front. So far so good. After going thru the recommended brake-in procedure the brakes feel MUCH smoother than before. Obviously fixing the rear drums helped, but the fronts are smooth now. No pull either direction when hitting the brakes hard, no squealing, just nice and smooth. 'Course it's just been 2 days so time will tell how good these are. 2-Thumbs up so far!!
Now so save up and get rid of these drums and replace w/some nice dics...![]()
KJ ones are hard to find, at least around here.What years where the ZJs? I'd just get all the gear off a KJ Liberty if I could find it. All in all I shelled out ~$100 for the drum brake gear (wheel cylinder, shoes & drum) so not much more & I could have discs ....
