Lowrange2
- Abbeville, SC
hell, new ones are 305.00
The spring on that side is a little bowed from a heat/straighten/weld on some plate fix job to the LCA mount on the axle. The body rolls to the right on left hand turns, and stays pretty straight taking right turns, so I think that has a little to do with that. I do need stiffer shocks probably as well, and longer ones.cal said:Get stiffer shocks.
The spring on that side is a little bowed from a heat/straighten/weld on some plate fix job to the LCA mount on the axle. The body rolls to the right on left hand turns, and stays pretty straight taking right turns, so I think that has a little to do with that. I do need longer shocks probably as well, and as you said stiffer ones, espeically since I put that ARB on the front.cal said:Get stiffer shocks.
cablesmurf said:I think you mean Trailmaster...
boise49ers said:Yep he did. I have the same set up. Trailmaster Drops with RE support brackets. You will want adjustable control arms too if you are going to off road it.
balloo93 said:You can still get the Trail Ready drop brackets, and use the RE support braces with them. The trail ready are around 1/2 the cost of the RE.
Call these guys up and ask about Just the lower and upper drop brackets.
http://rockymountainsusp.com/index.html
cablesmurf said:Your statement confuses me...why do you need adjustabe arms? RE sells the kit with fixed arms.
XJedi23 said:Can you / is it advisable use DB with Adj Upper control arms and fixed lowers?
boise49ers said:You would be ok if you have the braces. You won't get as much articulation. Plan on adjustable LCAs at some point.
XJedi23 said:I went to install a set a week or so ago and the boomerang parts of the brackets were not drilled properly and I didn't have the right tools to open up the hole. Has anyone else had that trouble?
It seams odd to me that the CA lengths would change. Dont they drop evenly?
