Drivetrain and a few other things
Lincoln
NAXJA Member #321
ID
2 close to new Timken wheel bearings off an '89 (50-100 miles) - $100/pr.
Pair of XJ Dana 44 shafts, come with the bearings and races, there is about 30K miles on these - $140/pr.
Carrier and Lockright for a 44 and 3.92 and lower (numericaly higher) gears, roughly 15K in miles - $150.
Set of Reverse Cut 4.10's for a 44, were on the above carrier - $50
Set of 3.07 D44 gears and Trac-lok. No clue on the miles - $40
Set of good 10"X2" drums off a D35, about 5K in miles. - $40/pr
D35 out of a '95 wrangler with 4.10's. I have someone that wants the gears so if you don't want the whole axle I'd be willing to part out the axles and ????. The axle has about 70K on it. - $100 for the entire assembly, PM if your interested in anything else.
'98 Toyota Tacoma 2x4 V-6 axle, 3.15 gears. This is a good swap for a cherokee because it has the 5x4.5 pattern and the width is correct. There are a few threads going on now about the swap. - $250
The following stuff is from a bunch of cooling experiments I did some years back:
Modine 2-row radiator out of an '89 (closed style). Used for about 2 months and has a few bent fins where the fan clutch sits. Otherwise great condition. - $50
2 Hayden 10" s-blade electric fans, I believe they are 500-600 cfm - $20/ea
1 Scotts 10", this one is 1000 cfm - $50
1 Scotts 11", 1100 cfm - $60
Let me know if you want pics of any of this. I'm in Boise, ID 83709 and if I need to ship any of this you will be responsible for the actual shipping costs. I will be in Northern Idaho on the 10th and 11th if anyone is up there and interested.
