saybye said:
whats the benefits of one vs the other?
oviously double is more fab time, but is it worth the extra time spent?
Read my post #2.
I did double-tri on mine. No regrets. You have better ground clearance and better performance overall, at the expense of having to do more fabrication work from the start.
Is it worth it? Depends on what you're going to wheel. Hell, the entire concept of going to a 4-link rear in an XJ may or may not be worth it. Consider this:
- What are you looking to improve over the existing setup?
- What are your biggest complaints with the existing setup?
- What are you looking to be able to do with your XJ?
If the first thing that comes to mind is "more flex", stop thinking about 4-links and either get lockers or learn how to wheel. You can get plenty of articulation out of leaf springs if you set them up properly.
Here's how mine looks underneath:
and a shot that shows the undercarriage ground clearance:
You won't get that with straight lowers, but you can get it with leaf springs.
Needless to say, I'm an advocate of the double-triangulated setup.
