tcharon
- Lake Tahoe, NV
This is a Double Dirt Bike Carrier. Made by GC Carriers in OK. I have never removed it from the original packaging but it might have a few small rust spots. Never used. It has the break away option so you can remove one of the ramps if you only carry one bike. A longer loading ramp for ease if your hitch is high. Includes 4 ratchet tie downs. Rustoleum paint in Silver aluminum color. Costs $468 new. The rails come stock with a “Y” design coming off the 2x2 sq. tubing helping eliminate the sway you find in other brands. The channel that the bikes set on is 6" wide and 75" long. Measurement from the hitch pin to the center of the first rail is 19 1/4". Square tubing that comes out of the receiver is 60" in length. Carrier has 8 tie down points making it very stable when traveling over rough terrain or on the smoothest of roads. Fits 2 inch square receiver. Rated at 300lbs per rail you can’t go wrong with this purchase. It has a 7 year warranty for defects. $270. Call Tom 250-423-7722, Skype thom.charon. I can bring it to Fall Fling or meet you on my way down I-15 & Hwy 6 to Moab 10/1 or 10.
