well the heater controls could move up to the stereo spot, and then remove the center vent... but i dont know if it is a whole duct behind the vent or not? if so then would take some modification
The center "vent" is attached directly to a MUCH larger piece of plastic, which is your duct work. It wont work without completely moving your controls to a different spot, and unless you are good at fabing cables, that will be much harder to do than its worth. I installed a 7" TFT monitor, and it BARELY fits. Its only about 1/2" thick.
