Door Speaker Depth?
Veeb0rg
Glen Burnie, MD
anyone happen to know how much depth there are in the front doors? I'm on a shopping spree to replace the front door speakers and I need to know how deep the door is in that area.
Thanks
I don't have the exact dimenions. I can say this. I have 6.5's mounted in my door, and there is still another inch of availible depth before the magnet will reach the glass. If you want, I have a pic that I can post up this evening or tomorrow.
If it's just a standard speaker, you will probably run into diameter issues before you max out the depth.
I've had luck with most brands fitting in my 2000 at the 6.5 inch size. Only problem i have ever run into are 6.5 inch memphis msync components are too deep for the doors in my 98, so i had to move to a 5.25.
In my 2000 ive had infinity, mtx, and finally jl all components. 98 ive only tried the memphis.
Mounting depth on the front door speakers is only an issue with the 97+ models, due to the full length glass.
The original poster has a 95, which he failed to mention. The glass will not interfere with the speaker. So you can pretty much put any 5.25" or 6.5" speaker in there.
