I didn't have too bad of a time getting the doors to line up again. Once you get them lined up, you won't have to do it again. I think it would be easier to "hang" the doors each time you put them on, then to have to line the hinge holes up and put the bolt back thru them.
I drilled my pins out, and then used 4mm allen keyes as pins. They were very easy to get in and out, and they would never slip through since they were an L shape.
You bet, and everything else, wind etc. You had to kinda move the door up and down/ side to side to get the keys in, they were a perfect fit, so they felt just like the pins did.
I just used a dremel with a metal cutting disc. cut the pin right in half, then pushed both end out. On some of the doors I didn't even have to remove the hinges.
