There are other ford 9" axles out there, but the 78-79 F150s are the most common.
If you stay at 7.5" of lift, and the 8.8 is working at that height (driveshaft doesn't bind up, and pinion bearing isn't making noise due to excessive pinion angle and lack of lubrication) then a 9" should work as it isn't too much lower than the 8.8.
A semi float dana 60 (full float if you are going to 8 lug wheels) has a higher pinion than both the 8.8 and 9, and may be a good option, but is harder to find.
A high pinion axle would have to be made from a ford front dana 44 or 60 that has been re-tubed, or a 9" with a currie or truhi9 center section.
