JeepGodXJ
- Oceanside, Ca
I just wanted to get your guys opinion on how my coil springs compress. Maybe its just me and this is normal, but its driving me nuts.
When the spring expands, it looks normal. But when it compresses, it "bends" so to speak. Now I know that it's not going to be perfectly straight, but to me it seems like its bending too much. I have the pinion angle set correctly to make the driveshaft angle better, and also IRO adjustable control arms. I also understand that when compressed, the pinion angle is going to force the bottom of the spring out, causing the spring to bow out. NOTE: This is under FULL compression. Well at least as much as I could do at the time.
I guess my question is, is this bowing too much? Or should I just let it be since its not causing any problems?
Btw, I have around 7.5-8.0" of lift, I know its tall, and im going to rectify that, but for the time being, I just need it to work. Flame Suit Activated...
