Does anyone want to help me on Sat???
poomero
Tigard
90xj 4.0 3 inch lift
Here is what is going on. When I hit the brakes I have brake chatter. When I hit the gas I hear popping. when I let off the gas I hear a grinding noise. When I go over a bump or a dip in the road and I am on the gas there is a crazy grinding sound.
I just changed the Pads, Calipers and rotors.
I looked at ever bolt and nothing is loose.
I greased all the fittings
Changed all the fluids and checked them to make sure they are full still.
I need help by someone who may know what is going on by riding in the jeep, so if anyone will be around I will be in San Jose and would love the help. Please let me know and I will let you know where I will be.
Thanks Guys. __________________
jack up the side you feel noise is emminating from, put left hand on bottom of tire, right hand on top of tire, and shake tire back and forth in and out to see if there is movement, if you hear a lunk or clunk noise, may be a bad wheel bearing.
