Do I have Vibes?
RTownsend
Gainesville, GA
I just installed a used OME lift on my 91' and have noticed that I can sometimes hear a rumbling coming from the rear. As far as actual vibes, I can't say I can feel anymore that I had pre-lift.
When most folks mention vibes do they mean something that I will know is present or is my hardly noticable noise considered vibes?
Should I just ignore it? I'm sure after a few thousand miles I won't notice it at all. If not do I just make sure the TC and pinion are parallel or do I point the pinion toward the TC a little bit.
I need another 1" in the rear and now would be the time to add some shims.
BTW I'm only about 1" over stock and will end up at 2".
