disco install problem. need help
jeepster
Chattanooga, TN
Well i just installed my first lift on my first cherokee!!!! i have a 97 sport, and just installed a RE 3.5 super flex and netted 4.25 of lift. also put on rancho shocks and steering stabilizer. No death wobble and no drive line vibrations. so im very pleased with the whole setup.
the problem is that when i went to install the discos i could not for the life of me get the bottom end link out, tried an impact, torch, beating it out, everything and it wouldn't budge. any suggestions? any help would be very appreciative.
thanks
Jeepster
I don't know why they put a torx bit head on it cause that bolt is pressed in. I had to just cut mine off and drill them out.
You can try these also:
Air hammer
C clamp and a socket
Some type of gear puller as a pusher
or the one mentioned above cut and drill
mark
Like Mark said...air hammer. Quick and easy. If you don't have a compressor, you must know someone who does. Literally takes less than 10 seconds to do both.
