- Port Orchard, WA
Copied from Goatman's posts - thanks Richard - hope you dont mind! :gee:
Here are directions:
Take Hwy 168 heading NE out of Fresno/Clovis, towards Shaver Lake and Huntington Lake. The new freeway through Fresno turns into Hwy 168, so you can take it off of either Hwy 180 if coming from the north or Hwy 41 if coming from the south, check your map or Mapquest so you can see your route depending on which direction you're coming from. So, heading NE on Hwy 168, follow the signs to Shaver Lake, which is roughly an hour drive from Fresno. As you are coming into the town of Shaver Lake, make a right turn onto Dinkey Creek Rd, where there will be a sign saying Wishon and Courtright Reserviors. Continue on Dinkey Creek Rd for around 12 miles, and as you are coming into Dinkey Creek, look for another sign saying Wishon and Courtright Reserviors. Make a right turn at this sign onto McKinley Grove Rd......very important! If you miss this right turn, you will drive past the ranger station and the Dinkey Creek store and end up at Dinkey Campground. After making the right turn onto McKinley Grove Rd, immediately crossing the Dinkey Creek bridge, go for about 1/4 mile and look for the Camp Fresno sign on the left. At this sign, there are two roads that go to the left, the first cuts back sharply and goes to Camp Fresno, the second is road 10S36. Turn left onto 10S36 and immediately turn right into the trees, which is our camping spot. The camping is in the trees, but there is enough open space for trailers if needed. There is an outhouse down the road a short ways, and at the ranger station, and showers at the Dinkey Creek store.
It's best to gas up in Prather, you can easily run the trail and get back to Fresno on one tank. Also, block ice lasts much longer than cubed ice.
approximate location on google maps hereTake Hwy 168 heading NE out of Fresno/Clovis, towards Shaver Lake and Huntington Lake. The new freeway through Fresno turns into Hwy 168, so you can take it off of either Hwy 180 if coming from the north or Hwy 41 if coming from the south, check your map or Mapquest so you can see your route depending on which direction you're coming from. So, heading NE on Hwy 168, follow the signs to Shaver Lake, which is roughly an hour drive from Fresno. As you are coming into the town of Shaver Lake, make a right turn onto Dinkey Creek Rd, where there will be a sign saying Wishon and Courtright Reserviors. Continue on Dinkey Creek Rd for around 12 miles, and as you are coming into Dinkey Creek, look for another sign saying Wishon and Courtright Reserviors. Make a right turn at this sign onto McKinley Grove Rd......very important! If you miss this right turn, you will drive past the ranger station and the Dinkey Creek store and end up at Dinkey Campground. After making the right turn onto McKinley Grove Rd, immediately crossing the Dinkey Creek bridge, go for about 1/4 mile and look for the Camp Fresno sign on the left. At this sign, there are two roads that go to the left, the first cuts back sharply and goes to Camp Fresno, the second is road 10S36. Turn left onto 10S36 and immediately turn right into the trees, which is our camping spot. The camping is in the trees, but there is enough open space for trailers if needed. There is an outhouse down the road a short ways, and at the ranger station, and showers at the Dinkey Creek store.
