- Ocala, FL USA
As soon as I get the 4wd AW-4 and D-300 in my MJ in the next week or so I will be setting money aside for a few weeks/months to get some decent offroad tires. I plan to run street tires on it on the street due to it seeing a fair bit of DD use and having a welded rear end and then will just mount the offroaders on a second set of rims and use them only for offroad.
I will most likely end up running 35's or 36's. I will have to stick with 16" or bigger rims due to the front brakes being too large to run a 15" rim. I have a 14 bolt rear and 10 bolt front (which is not locked). I was thinking of running a wide set of boggers in the rear (35X16) and then a set of pizza cutters up front...either 35X10.50 boggers or even Q-78's. I would like to get a set of 36's even if just to get a slight bit more clearance under the 14 bolt but there aren't nearly as many width's to choose from. Or maybe a set of 36X13 TSL's in the rear and some Q-78's up front.
I was thinking the narrower tires up front would probably put less stress on the steering and the 10 bolt axle overall than a wider set would and I have no worries on the 14 bolt with onyl a 35" tire regardless of how wide it is.
