Diff Rebuild Time
techno1154
In the islands
I need to rebuild the diff's in the old XJ. I also want to regear and add some form of traction device. Where do I find the best value for money? Complete rebuild kit including seals and bearings are also needed. Thanks.
well. as far as rebuilding your diffs. if you stall a locker you are going to need a rebuild kit anyway... Try your local 4wheelparts store. I have a buddy that works there so I get some discount on whatever I need to buy. (ie lockers batterys rebuild kits etc.) they can match most peoples price so that would be a good place to start..
as far as traction goes. I went with a ARB up front and a Detriot in the rear. If yours a Daily driver and you dont feel comfortable driving around with a full locker, than go with duel ARBs. it will be a bit more expensive but your tires will thank you for it. there are a bunch of LSDs (limited slip) out there but why waist money on a half locker?:D
a diff rebuild kit can be bought for somewhere around 100-120 dollars includes all the bearings/ shims / nuts / seals. so you should be set after that.
you should consider having some sort of 4x4 shop install your gears for you. whichever ones you pick.
