winterbeater
- Royal Oak, Michigan
Also, Nick changed the fuel pump just before he discovered his CKP issue.
I'm sorry I have not been on to update this.
This is confirmed, my Jeep is fixed.
The Crank Position Sensor was the problem.
Again thank you all for your help, you can move this into a fixed or closed state.
I'm sorry, but I don't buy it.
The pump's operation, other than not running if the ECM is not getting an input from the ignition module, is not affected by the CPS.
If so, I'd appreciate the "science".
My fuel pump is still under warranty, I am not going to buy another pump for it.
here is a picture of the 1st new pump I installed after i pulled it out of the tank:
