Here is the problem with strokers: heavy and not rev happy.
An aluminum 5.7 weighs less and makes more power. Plus, it will actually rev, making it useful for racing. Strokers are great for torque, but I'm not driving a tractor trailer. If I could get a 10 lb flywheel, I'd entertain the idea of milling the crank down in the hopes of actually getting it to spin up quickly. I've thought about the Hesco crank sensor relocator, but I'd still have to do a custom flywheel, or use a Camaro flywheel and clutch (if the dimensions are close enough). But if you add the cost of a new flywheel, clutch, and crank sensor kit, I'm halfway to a junkyard hemi. Plus the head on the 4L is terrible for high rpm airflow.
Engine options alone make switching to an S10 a good idea. If I could just hit the lottery, I could build an awd V8 GMC Safari and make it look like the A Team van. Then all I'd need are some SFI approved gold chains...
