- bourbonnais IL
1987 Jeep XJ Wagoneer
4.0 litre 6 cylinder
AW4 Transmission
NP242 Transfer Case with Novak transfer case shifter and Tom Woods SYE and drive shaft
37" Pit Bull Rockers
15x10 Aluminum TrailReady Beadlocks
4.5" lift
Chevy pickup front brake lines
Late model brake booster/master cylinder
Rusty's adjustable upper and lower control arms
PSC performance power steering pump
Durango steering box
Brown Dog Offroad Poly motor mounts
TNT Customs track bar
ARB air compressor w/tire inflator kit
D44 front axle w/5.38 gears, Detroit locker, alloy shafts, Nitro Excalibur u-joints, Chevy flat top knuckles, crossover steering
(all brackets have been moved up so nothing hangs below axle tube)
D44 rear axle w/5.38 gears, Detroit locker, alloy shafts, custom high clearance shock mounts
Rockcrusher rear diff cover
Riddler front diff cover
AJ's Off-Road Armor front and rear bumpers
AJ's Off-Road Armor rock rails
TNT Customs HD skidplate/belly pan
TNT Customs unibody stiffeners
HD Off Road Engineering Shackle Relocators
"Joel Built" custom gas tank skid
LED rock lights
Warn X8000i winch w/Masterpull Synthetic Rope and 12 Volt Guy in cab control
Optima Red Top battery
K&N open element air filter
Flowmaster 50 series muffler
Tube doors
Hunsaker Icon Seats
Uniden CB w/weather radio
Numerous beauty marks
Trail Rated Badge
91 XJ 4 door(less)
38 tsl super swamper bias ply, DIY beadlocks.
Front 44, full Detroit, Yukon shafts, Yukon super joints, full hydro steering, rustys 6" coils, custom radius arms.
Rear Ford 9", full spool, ruff stuff pinion guard, Alcan custom leaves, rustys shackle.
Stock 4.0 w rustys air tube.
8 point cage.
Stock 231 w AA SYE, custom 1/4" wall DOM tube drive shaft
4 racing seats w/4 point harness.
Super cool flame paint.
Body has been dove tailed and new paint in rear since these pics.
Warn HS9500i winch, synthetic rope.
I'll play, since I still own it.
98 xj 4.0 with ax15
231-300 doubler
dana 60 front spooled
yukon 35 spline inners and outters with drive slugs
yukon super joints
hi steer
full hydro
3 link front (lowers are 2" 1/4 wall chromoly)
14 bolt rear (welded)
4 link rear (lowers are 2" 1/4 wall chromoly)
42" irocs
steel beadlocks
cutting brakes
tom woods shafts front and rear
tom woods spare rear and a extended stock front spare
m8000 winch
front suckdown winch (behind front bumper)
s.s. custom fuel cell that uses stock pump
yellow top relocated to back
4 point harnesses
all cage tubing is 1.75" 120 wall DOM
lets go! vote for your favorite......or who ever pays you more.
