Jeff-97XJ
- Atlanta, GA
97 XJ, 4wd, 4.0, 231, 3" lift.
My passenger rear (RR) window isn't working.
I put a new Master control switch into the drivers door and was expecting that to clear up my RR window issue. It has made it worse.
Previously it would go down but not up. (It is currently down to just 4" of window showing)
Before I replaced the master switch in the Drivers door, I noticed that when I tried to use either the switch in the drivers door, or the switch on the RR door, the light on the actual door switch would go black. Very odd. Is that indicative of where the problem is?
Oddly, when the RR door window stopped working properly, the RF window started working correctly. It had not worked at all for several month.
Pulling my hair out with this.
I really hate driving around with a plastic bag over my window opening.
Any help is appreciated. I really would like to get the window working properly, but in the meantime just getting it to go up would be an improvement.
Thanks for any help-
