- Virginia City, NV
I know the pinion angle is not really an issue as I will have manual hubs I can disengage. My only concern is this is a low pinion axle. I want to try and keep the yoke out of the rocks.
looks funny, nearly as small as the 30 shaft, but shouldnt matter. Force concentrates on the ends of the shaft, as you get toward the middle of the shaft the forces balance out to 0. Thats why you really only see shafts snapped right at the splines or at the U joints.
At first glance many shafts look close to the same since its hard to see a less than 1" different in shaft diameter , but a 35 spline 1.5" diameter shafts compared to a 27 spline 1.18" diameter shaft is night and day. Also, the d60 806 Ujoints make 760s look like little kids toyy
yeah I get that, I was referring just to the necked down part which is pretty small in comparison. The shafts are obviously bigger where it matters.
I know where you live...
