Chief93XJ
- Southcentral PA
I have a Dana 60 out of a mid 70's ford F250,must go, it has factory 4.11:1 gears, factory limited slip, full floater, 30 spline axles, huge factory brakes (rusty) and 8 lug. all the original mounts and brakelines are still intact. the side and pinion gears as well as the pinion shaft have started to consume themselves and are chipping apart, the carrier spins freely and there is no blueing from heat, but it will need to be rebuilt internally.you might be able to reuse the ring and pinion, they are not chipped up.I am not sure of the condition of the wheel bearings cuz i dont have the tool to pull the nut off of the end. the limited slip clutches look to be OK.I am asking $200 for a good start to a beefy project. I have no means of delivering this, so you will have to come pick it up. Located in south/central PA near RT22 approx 45 min east Pittsburg.thanks-Aaron
