Just wondering. What are some of the pro's and con's of the hp50's verses the hp44's. I know that the aftermarket has very little parts support for the 50's. But other than that..?
There are both TTB and straight axle versions. The ring gear is 9 inches instead of 8.5 in the 44's and they have 30 spline axles. That's about the limit of what I know about them tho.
Biggest "Con" is the limited aftermarket parts availability. Other then that, 'same 30 spline axles as the -44, with most of the weight of a full Dana-60.
'Not many real "pros", unless you come across one cheep, with gears you need, pretty much set up for what you want to do.
