5-90
- Hammerspace
Unless the front is also a 44, I'd not worry about it. If both rigs have similar transmissions (AW4 auto or any manual,) you should have the same gearing (3.55 for auto or 3.07 for manual, unless he's re-geared.)
The front is likely to be a D30 either way, unless it's been swapped.
Counteroffer - pull your rear axle (D35, right?) and take it with you. Swap for the D44. Take the D44 home. That way, he still has rolling stock (doesn't matter what gearing, and you shouldn't need to hook the brakes back up) so he can be quit of it easily. And, you don't have to worry about getting rid of your D35.
