dana 44 parts/hysteer
ipkyss
Hampden, MA
I have a f-250 HP dana 44, 1/2" wall tubes. Narrowed to waggy width, 60/61" 6 lug big spindle chevy outters. mid 70s flat top knuckles, Drilled and tapped with studs OTT hysteer Full Detroit locker for 410 and up gears I believe. stock waggy shafts. The housing has been cleaned and stripped of all mounts, Some surface rust from sitting. It is NOT togethere. I believe it has either 355 or 410 gears with a open carrier in it now.
I turned the C's and pinion angle for a xj with about 6-8" of lift, But have not welded the C's back on incase the angles need to change. This is a complete axle including all bearings brakes, ect. It is just not togethere.
$650 OBO
Located in Hampden,MA
