F150 76 front dana 44 high pinion axle, 1/2 thick tubes, narrowed to wagoneer width 61.5 inches wms to wms, axle has custom truss welded to top side, chevy knuckes milled drilled and tapped, 4:10 gears, trac loc posi, chevy spindles and brake calipers, ford hubs rotors, stock waggy axle shaft, heavy duty diff cover, new spicer ball joints, new inner axle seals, comes with new studs, hardware and a diff instal kit.
Inner c's are tack welded on and can be adjusted to fit your vehicle.
Steering stop welded on passenger knuckle.
$650 obo
Camarillo CA
$650 obo
Camarillo CA
