jake3240
- Norfolk, VA
So after about 2 months and a 4 hr drive, I finally found a 75 HP ford front dana 44 to cut down and narrow to waggy width. Unfortunately, when I cut off the radius arm mounts I discovered that the tubes were badly rusted & pitted out right in the middle of where I need to relocate the drivers side inner C to. I'm afraid if I shorten it, it would be a steering nightmare. So, I figure my best option is to leave it full width. Currently I have wheels with 3.75" backspacing and 1" spacers and I like the width, so I figure if I just get new wheels with stock BS and 5 on 5.5 lug pattern, I'll be pretty close to where I am now. My real concern is the pinion input/driveshaft. How far off center will the pinion be if I leave the axle full width with the axle centered under the Jeep, and will that cause problems? Any input/suggestions are greatly appreciated.
