I wouldnt waste time with a waggy lp44, I would do ford hp44 if you feel you must do a 44. That being said I built a pretty sweet hp44(trussed, chromos, ARB, 5.13s, etc, etc but imagine rehearing, replacing hubs, lockouts, spindles, bearings, ball joints all with quality parts and buying new chromos and even more crap from ruffstuff) and I regret it although huge piece of mind over the 30 after blowing it up. I could have build a ford hp60 for much less. I would have gone straight to a 60 if I knew now what I didnt know then.
the JK rubi 44 is a great idea, especially since you can find them cheap and they have those massive jk44 gears (rub icons only have the bigger gears right?) . Just don't get attached to matching lug patterns.JK is 5 on 5. hp44 is 5 on 5.5, or you can do 8 on 6.5. temporarily you can just run mismatched rims.
that all being said, you could probably get some chromos for the 30, get a cheap 90$ truss, and a ruffstuff cover, 40$ knuckle gussets and call it done.
really depends on your wheeling style. if you are going to beat your rig to death you should probably consider the 60
