Dana 44 Brakes & Locker
FearNoFish
Heber City, UT
Yahoo! I just scored a XJ D44 rear. Now I have a couple of questions for those in the know.
There is a older D44 in the local classifieds that was used in a Willys. It has disc brakes and and older ARB locker. This D44 was a high pinion reverse cut so I didn't want it but I remember reading that even the reverse cut carriers were interchangeable. If that is so, then I would think that the ARB would also be. It also has locking hubs (it was flat towed alot). I could probably pick this up for $500.
I also read somewhere that older ARB lockers had clearance problems at the air line. Is that a worry and how do ARBs hold up.
I can also get a Isuzu D44 with disc brakes for $50 bucks. The discs are missing but I would need new ones for my lug spacing. Anyone know if the basic hardware would be interchangable?
Any help would be appreciated.
BTW for you east coasts XJers. I found a couple of XJ D44s on Craigs list in PA and I have some info on one that was on e-bay a couple of weeks ago and didn't sell for $350.
How wide is it? Why not run it on the front of your XJ, and find a rear to match..
The carriers are interchangable and no airline issues with mine.
Which of the ARBs had a problem related to flex that caused the bolts to back out? Was it just in the smaller differentials?
