dana 30 with 4.10s and ruff stuff 160$
Status
Not open for further replies.
blondejoncherokee
sacramento
dana 30 with 4.10s and ruff stuff coil buckets and lca mounts
160$
located in sac
-jon
Hp with disco block off plate
I don't know much (anything) about the disco housings. Anything I'd want to know if I was going to put a WJ swap on this axle? Any difference as far as putting a OTA track bar in? I take it with the block off plate it is permanently, reliably and bomb-proofedly "on"?
the block off plate is just a flat peice of steel with RTV thats all you really need honestly. thats all the kits are....
other than that, i dont see much of a difference between the older housings and the newer ones other than those sleeve inserts for the ball joints, thats all i can think of. other than that i dont think there are any differences??? the pass side uca mount seems to be stronger on the disco axles since it all one big cast peice
100$ ????....
This is tempting, I need to find a matching rear or gears for my 8.25 tho.
Jon- How is the tracbar mount? Is it factory at this point?
there is no trackbar mount.
the lower mounts may or may not need to moved out a tab wider, they are beefy, but angled in slightly.
there is a 4cyl XJ with 4.10s dana 30/35 combo at pnp in sunrise out here in sacto.
just so you guys know pnp charges 284$ + tax for a front end and 160$ for rear.
if someone wanted a cheap tempory 4.10 rear to match they could grab that...
I'd love to grab it from ya, but I'm in Southern California about 50 miles east of Los Angles.
If you happen to know of anybody coming out to the Hammers next week, I'm on the way.
yah i got this axle. no one showed up.
how about 100$ obo?
To confirm.. this will need a new trackbar mount?
it will need a new trackbar mount
revrok is first in line as of right now just everyone knows.
jonnie walker is second
I'll come by Sunday afternoon if you'll be around... Pm sent
revrok picked it up sunday.
sorry johnnie walker.
small shafts i reccomend reading a thread before you post LOL!
It's not a big deal, it would have pushed me in that direction to go with larger tires with the 4.10's, but 30's will be just fine (=
sold!
Status
