ocalajeeper
- in the woods
I've got an 88XJ D30 disco. I'm about to get a 96+ D30 non disco. The 96+ doesn't have brakes. Can't I just put my rotors and calipers from the 88XJ on or is there more involved? thanks.
The unit bearings are different, and the rotors have a different hat depth. Swap the whole knuckle over to keep it simple.
I'm not going to need a press to swap the knuckle over will I?
No, just a BFH.
I've got a 87 4.0 auto with an NP242 on 31" tires and am about to put an ARB in the D30. Crash's original writeup says to avoid going 30-spline because it will leave the R&P as the weak link, but that is with 35" tires. Would this also be the case with a smaller 31" tire? If I can go with a 30-spline carrier and axles, is there an XJ model that has stock 30-spline shafts? For cost reasons, I'd like to run some stock 30-splines (if they exist) out of a wrecking yard while I save for some good chromoly ones.
Anyone have the measurements on stock upper and lower contol arms for mighty dana 30? Im building some control arms and dont have an axle to measure the width i need to make them. Ive found the length, just cant find how wide to make them.
I'd swap the 95 anyways. It's newer, you won't have to worry about the vac disconnect stuff, and most parts will be interchangeable, so if your 89's rotors are better, you can swap them over.
