Dana 30 rubber o-ring... where to get
IslanderOffRoad
Houston, Tx
I damaged the o-ring that goes around the axle seals yesterday. I used a crap ton of RTV to repair it but would feel better replacing it. This is the o-ring that keeps the dana 30 from leaking where the tubes press into the pumpkin.
Can i get another one of these or should I just weld my tubes to ensure it doesn't leak?
This is what he's talking about:
thanks cal
It's not an o-ring, it's silicone that was installed at Dana when they set the inner axle seals in.
so rtving it was the right way to go? or should i put something else in there?
Thats how i did it. When i tore my D30 down i was questioning the same issue... did a search here and found it actually being silicone. Just repeating what i'v read here previously.
I'd stop worrying about it. ;)
Thanks!
