blondejoncherokee
- sacramento
so i just swapped a front end i built up mildly into a buddys rig
- 4.10s, lockrite, with bigger newer style ABS shafts, LCA skids -
and i replaced the inner axle seal with the napa one that everyone uses(forgot the part number) and made a block off plate.
we went to slide in the big guy and he is too wide for the intermediate shaft bearing, we were running lae so we swapped a 260 one peice shaft we had lying around for the meantime.
what is the easiest way to remove that bearing?
obviously we can pull the carrier and the driver side shaft but i was thinking more like some kind of extension on a slide hammer or something like that?
anyone make their own tool for this before?
