Dana 30 High Steer kit
jeepdude25
So I installed my Teraflex High Steer kit, but Im hearing a rubbing sound when I turn either right or left. When it drives straight its fine. Ive turned the wheels and dont see anything touching and I have ground down all the little knobby ends on some of the joints. I switched to ZJ rotors which helped alot. At first I couldnt even steer with the XJ rotors. The only other thing I can think of is maybe my wheels are to small. Im running the 15x7 Black Rock Krawler wheel. Does anybody know If I need to run bigger wheels like 16's or 17's. And does anyone else on here run a Teraflex High Steer setup i would like to see some pics. I had to cut off my steering stabilizer bracket and remove the axle sway bar mounts. Im not running a steering stabilizer at the moment. And I have some bump steer but I plan on getting the Currie Antirock sway bar kit soon and fab up some new brackets. Thanks Fellas:viking:
I run the tera flex kit on my jeep with 15x8 rims, ~3.75" backspacing, and don't have any of the problems you described. Maybe post up some pics if you can? And I'm curious what the difference is between xj and zj rotors and why that helped, I thought they were the same.
Are you sure everything is tight? Maybe have someone else turn the wheel while you get under the jeep to see if you can see anything?
Sounds like a lot of BS to put with for a highsteer kit that merely puts the tierod on the top side of the arm. You sure something else isn't going on here?
Im guessing that its going to be the rim/tire rubbing on the tie rod or drag link rod ends. I run a 16" rim and it just barely clears on the rod ends. I cant imagine clearing them on 15's. I would also look while cycling the steering if the tie rod is contacting where you had to cut of the stabilizer bracket.
TeraFlex High Steer Kit Questions Answered!
Many questions have been brought up about the TeraFlex High Steer Kit for TJs. When and why do you need it? What other components or modifications do you need with the kit? How do you know the High Steer Kit is installed correctly? All of these questions and more are answered in this article.
First off, lets address the biggest factor in determining what you’ll need to be able to utilize the High Steer Kit effectively, that is, your suspension.
The High Steer Kit was originally designed to be used with the TeraFlex TJ MAX-LCG suspension system. This system, which utilizes a front 4-link triangulation, requires a High Steer Kit in order to properly align the drag link and tie rod to be parallel to each other. There is no other option since the MAX system does not use a trackbar.
The benefits of a High Steer system installed quickly leaked over to owners of the PRO-LCG suspension system, which is a 4-link trackbar system (sometimes called a 5-link system). The important thing to know for using a High Steer Kit with a PRO suspension system is that you’re going to need a couple extra parts that aren’t included in the regular High Steer package in order to correctly install it, as well as a minimum 4″ lift; however, we strongly recommend 5″+ to allow for proper clearance. Because the system gained so much popularity with PRO suspension systems, a separate kit called the High Steer Kit for LCG Suspensions was designed that includes a few more necessary parts which are: 1) 4″ quick disconnects and 2) left and right swaybar mounts.
The swaybar mounts and disconnects are crucial for proper installation of the High Steer Kit on a PRO system because it is necessary to move the swaybar away from the drag link and tie rod so they don’t come in contact.
Let’s take a look at the diagram on the right (click on it to enlarge). This contains three different alignment configurations; we’re going to focus on the top and middle sketches. The top sketch shows a high steer kit installed with a stock track bar (notice the angle the drag link makes with the track bar). The key to proper installation of the high steer system is to have the trackbar and drag link as closely parallel as possible. As you can see in the top sketch instead of being parallel the two make a very acute angle. This alignment would result in horrible handling and a dramatic increase in bumpsteer. In order to correct this, three additional parts are needed which are not included in the package. These are a custom trackbar and both frame and axle side trackbar brackets.
Until recently, you had to buy all of these separately. We’ve finally come around to bundling them all together in a nice little kit- p/n 4923200. This kit is crucial on a PRO-LCG system because it allows the trackbar to align parallel with the drag link of the High Steer kit.
Now, lets go back to the diagram. If you look at the middle sketch, you’ll see two orange brackets that have been installed to the track bar. The top bracket attaches to the frame while the bottom attaches to the axle. With these brackets in place the trackbar is parallel to the angle the drag link makes. Now, you might not always be able to get the two exactly parallel, but the goal is to get them as close as possible for maximum efficiency and control.
One thing to be aware of is the caster alignment of your vehicle after installation of all these mod’s. Having too much negative caster will cause the bracket from the trackbar to come in contact with the front differential…and that wouldn’t be a very fun experience to have happen.
Here’s more or less what a correctly installed system would look like with all the equipment we talked about here. Notice how the trackbar and drag link run parallel to each other:
<!--[if !supportEmptyParas]--><!--[endif]-->
That about sums it up for the High Steer Kit. If you have any more questions or concerns feel free to contact customer service at (801) 713.2303 for more information.
Thanks alot raptor that was very informative. I think I figured it out I think I need wheel spacers. The front knuckle is rubbing the inside of the wheels so I will just get some spidertraks wheel spacers and call it good!!!
You welcome! :patriot:
