blondejoncherokee
- sacramento
Alright ive been searching like crazy , but with no luck.
I helped a buddy years ago do a dana 30 CAD disconnect delete . threw a regular, long side shaft, non-ABS. last year threw an ABS shaft in there and had to knock out the outer bearing and seal just to get it in, and the old inner seal we swapped in from years ago was completly missing when we pulled the carrier to check things out. We got a new seal, napa 11800, and its loose in the tube. we RTVd it in, but sure enough, it came out on the drive home. the 2" OD is too small for the tube. and the old outer seal that used to sort of help is totally gone.
Anyone ever done a CAD disconnect conversion with one of the big ABS shafts ?
