J jimmy21669 NAXJA Forum User Location Hagerstown, MD Jun 16, 2010 #1 Will the Dana 30 carrier out of a JK work in a 97 Cherokee Dana 30? I need real knowledge on this before I proceed. Thanks
xjtrailrider NAXJA Forum User NAXJA Member Location Roanoke VA Jun 16, 2010 #2 The carrier should be the same for any D-30 provided it is the same ratio. The carrier break on the D-30 is 3.73
J jimmy21669 NAXJA Forum User Location Hagerstown, MD Jun 16, 2010 #3 I have heard that: A) There is no carrier break on a JK D30. They use thick gears to offset. B) A JK D30 requires thrust shims...
Goatman NAXJA Forum User NAXJA Member Location Bakersfield, CA Jun 16, 2010 #4 I don't have a definitive answer, but I really believe it is different. A quick call to any drivetrain or gear vendor will tell you......in about 2 minutes.
xjtrailrider NAXJA Forum User NAXJA Member Location Roanoke VA Jun 17, 2010 #5 jimmy21669 said: I have heard that: A) There is no carrier break on a JK D30. They use thick gears to offset. B) A JK D30 requires thrust shims... Click to expand... I hadn't heard that and I own a JK but I will take your word for it:exclamati Follow Goatman's advice and check with a vendor.
